Magneto assembly for AC WD45
Mark Hannesschl
07-21-2004 21:53:45
Looking for a complete magneto assembly for my Allis-Chalmers WD45,if anyone has any info it would be much appreciated.
Thanx in advance.
Mark H
1955 Allis-Chalmers wide front (Gas)
Purchased in 1985
Working tractor,all origanal.
Steve in N.J.
07-22-2004 15:27:52
 Re: Magneto assembly for AC WD45 in reply to Mark Hannesschlager, 07-21-2004 21:53:45
Mark,
We can help you out with a mag if you need one. We rebuild, service, exchange, and sell parts for Fairbanks, Wico and other magneto manufacturers. We also offer a mag to distributor conversion for your machine with an optional electronic ignition for a more maintenance free system. Drop us a line if interested... Thank You Ron for the referral! It's appreciated!!
Steve/B&B Custom Circuits
JMS/MN
07-22-2004 23:26:03
 Re: Re: Magneto assembly for AC WD45 in reply to Steve in N.J., 07-22-2004 15:27:52
It is a WD45- the original equipment was a DISTRIBUTOR.
Mark Hannesschlager
07-22-2004 19:14:33
Steve,
Thanx for your prompt reply�.if you could send me out your catalog that would great�..what is the the charge for it?
I would be also interested in a complete over-haul of the electrical system as well,as I am always having to boost the old allis,converting over to a 12 volt sytem would
be considered too�..i also need an alternator.Anyways�.it�s great to see there is someone out there for the AC�s�
Thanx again
Mark
Ron(NWOH)Try Steve
07-22-2004 07:34:14
Try Steve at B&B Coustom Circuits Ph.No. 973-697-5747 www.chevy2performance.com HTH Ron
JMS/MN
07-22-2004 07:17:02
All WD45s used a battery ignition, with the distributor. Most WDs had the magneto. If the unit with the spark plug wires is vertical, it is a distributor. Much better starting system than the magneto.
Brian G. NY
07-27-2004 14:10:55
 Re: Re: Magneto assembly for AC WD45 in reply to JMS/MN, 07-22-2004 07:17:02
Both my WD and WD-45 have distributer ignitions. A lot of people might take exception to your statement about the distributer being a better starting system. A properly set good working magneto will probably give a "hotter" spark than the battery ignition system. I assume that is why so many old time flathead Ford hotrodders used those neat aftermarket magnetos
