Plate on side of WD motor?
Kevin Kostiuk
07-20-2004 19:50:01
What is the plate on the side of the engine block? The oil filter housing is mounted to it. It appears to be leaking oil all around it. I've never seen a motor with a plate like that on the side of the block. I think I'm going to remove it and look for my oil leak. Is there anything I should be on the look out for?
Kevin Kostiuk
07-22-2004 17:38:55
 Re: Plate on side of WD motor? in reply to Kevin Kostiuk, 07-20-2004 19:50:01
Thanks a lot guys. I pulled that sucker last night. It's pretty easy to see why it's leaking. That gasket is nasty. Easy enough fix. Thanks again.
Joe M
07-21-2004 19:00:39
Kevin, it covers the pushrods and the lifters.It is made of very thick cork. AGCO has them, or you cane cut it from a roll of cork gasket material. NAPA has the raw cork, might have the gasket too. Left you a picture in parts and pieces of what it covers. Picture is from my WC but this part is the same.
gene
07-20-2004 20:53:08
Oil from the rocker arm assembly drains back into pan on that side of the engine. That area is not under oil pressure. The leak is probably from the gasket under the plate (very common) or from the valve cover gasket. Nothing special to look for or to be aware of. You might try to tighten up the bolts holding the plate. If that doesn't work use an ATV sealer instead of the cork gasket.
Matt
07-20-2004 20:13:11
If I remember correctly the plate just covers the push tubes and possibly lifters. I do know there is a gasket for the plate and that is most likley bad and where your oil leak is comming from. Hope this helps. Matt
