Wide front stuck
Big Orange T
07-20-2004 14:31:37
I have a WD-45 adjustable wide front. I need to adjust to a notch or two narrower and it is STUCK. Any suggestions on freeing the front end???
wdTom
07-20-2004 18:27:27
 Re: Wide front stuck in reply to Big Orange T, 07-20-2004 14:31:37
Some years ago we had to break the adjustable front of a B loose. I remember putting a hydraulic jack between the spindles, just under the axle. I don't remember just how we rigged it up. That and a lot of hammering, penertrating oil. That axle is open on top, now we make sure to put oil in the opening every so often to prevent it from rusting again. Is the WD/WD45 axle open on the bottom as I think I remember? Maybe take it off the tractor and wedge the opening open slightly so oil can get in?
GOCATS!
07-20-2004 15:18:51
I've heard of one method, loosen up the clamps/bolts, and drive slowly across fairly rough ground(a cow pasture) and let it work loose. Penetrating fluid before is required. Don't know if this will work for you, the "heat wrench" and a large hammer is next.
