WD Hydraulics lever (will not stay put)
Ryan Rudd
07-19-2004 12:24:49
Hello, I have a 51 WD that I just recently set up for a brush cutter (3 point). This is the first time I have used the hydraulic lever. The lever itself does not "snap" into the slots to stay in place. I am constitently raising and lowering it to keep it mowing decent. Does anyone know of a solution or a parts place that would carry these. Others have had to run into this issue before. Any help would be greatly appreciated. Thanks.
Kenneth Comstock
07-24-2004 21:08:02
 Re: WD Hydraulics lever (will not stay put) in reply to Ryan Rudd, 07-19-2004 12:24:49
I was have this problem the lever was causing my bush hog to raise and then lower. To stop it from raising I have to lower it causing the mower to mow to low. So I made a set of chains and brackets mounted at the 3pt hook ups looking like an inverted V. It works great now. and keeps the mowing height. Good luck.
Dave in Mo
07-21-2004 09:14:56
I went ahead and made a pair of chain stays for my WD for brush hoggin' etc. They allow quick adjustment when the 3 point is raised since the slack chain is easily moved thru the key hole slots. Someone in the past on this Forum has posted a picture of these accesories or you can buy them.
Butch
07-19-2004 15:41:01
My experience is the great magority of the time people dont know how to set up the hydraulics for hold. Get an operators manual so you not only know how to set the knobs and valves, but how to set the linkage so the hold valve can work. Far less times there is a problem with the hold valve itself and most of the time it's simply dirt holding the ball off the seat. Once I have needed to renew the ball and seat. If the linkage is properly set the hold valve detent will hold the lever in hold posotion even if the friction blocks are non-existant.
Dave Grubb
07-19-2004 14:18:52
There are supposed to be friction blocks on your throttle and hydraulic hand levers. These ride on the aluminum tracks the levers are fastened to. There are springs behind the tracks that put a tension on the friction blocks. These can be too worn to do the job. You must have the hydraulic system set up to operate in the 'hold control' mode. The system cannot have any internal leakage of the hold control valve or the load will constantly creep down. To check the hold control valve for internal leakage raise the mower all the way up, leave the hand lever fully up, shut off the tractor. A good valve will hold the load for ever.
Ryan Rudd
07-29-2004 08:34:34
 Re: Re: WD Hydraulics lever (will not stay put) in reply to Dave Grubb, 07-19-2004 14:18:52
Thanks for all the great replies. I knew I came to the right place. I'll see what I come up with. Thanks again for the help.
