Flat top Wc fender bracket
Bob in Wi
07-17-2004 22:54:39
A friend of mine needs a fender mount for a un styleled wc 1937. I got on of e-bay the was for a styled. wrong one. need on that is not broken.
gene
07-20-2004 14:14:13
 Re: Flat top Wc fender bracket in reply to Bob in Wi, 07-17-2004 22:54:39
I have two brake cover housing (used prior to tractor number WC-83878). They are off of a 37 WC. Allis part number is 209021. Casting number U2536. Condition, usual rusted, not broken. Both left and right sides are identical. When reversed, the location of the brake eccentric is moved from one hole to another. Depending on which side you use them on the bolt holes will need to be chased. If interested post back. Price will depend on your location/shipping cost.
gene
07-18-2004 18:03:01
Front and rear fender mounts/brackets for the unstyled WC are the same. They can be easily made by most home mechanics and certainly a welding shop. The bracket is nothing more than 3/8" thick steel bent into a "J" shape.
Check this board and the Unofficial Allis Forum. I measured up and posted the measurements of the bracket about 6/8 weeks back.
JMS/MN
07-18-2004 23:01:12
 Re: Re: Flat top Wc fender bracket in reply to gene, 07-18-2004 18:03:01
You are correct in your post regarding the flat iron brackets, but the poster might also be referring to the cast brackets that mount on top of the rear axle housings. The ones for the unstyled are different than the styled WC. I have each, but had to rebuild the mounting holes for the unstyled, since the later ones were different.
Bob in Wi
07-19-2004 08:31:02
 Re: Re: Re: Flat top Wc fender bracket in reply to JMS/MN, 07-18-2004 23:01:12
The brackets I'm looking for are the cast iron ones.
gene
07-19-2004 18:41:19
 Re: Re: Re: Re: Flat top Wc fender bracket in reply to Bob in Wi, 07-19-2004 08:31:02
I have a set from a 37 WC parts tractor. I'll check their condition tomorrow. Should be ok, I didn't really check their condition - I just wanted the fenders.
If you don't find a set, post back. I live in Central Missouri.
Gene
Bob in Wi
07-20-2004 21:38:09
 Re: Re: Re: Re: Re: Flat top Wc fender bracket in reply to gene, 07-19-2004 18:41:19
My friend found some at a junk yard. He took a load of junk there and found one on a tractor. Thanks any way.
