replacement motor for a CA??
Rob
07-12-2004 11:02:06
is there motors out there for a CA the motor needs to be replaced just don't know where to look
thanks to all who reply
ACEd
07-17-2004 17:58:06
 Re: replacement motor for a CA?? in reply to Rob, 07-12-2004 11:02:06
Motor from late B or from C will work - look for prefix CE (as opposed to BE which would be same attach geometry but smaller displacement) There are some suffixes that may be of interest as to compression ratio - I seem to recall PA as most desirable, later higher compression suffix typically found on CAs. Earlier suffixes were GA and before that just G. Only ones to stay away from are K which were very low compressionn but if you are going to rebuild, all you really need may be the block and they were all the same as I recall.
Dick L
07-12-2004 11:12:36
Shoot me an email to the above address as to why you need a new engine and I will see if I can help you.
