new owner help.
daniel.b.loyd
07-12-2004 07:49:21
i just bought a 51 c model with an old but still good belly mower. do not know brand of mower.
mower has no blades or belts. where to get them?
also the tractor has a single front wheel and it
has a tight turning radius to the right but takes a 1/2 acre to turn left. can this be adjusted for a tighter turn to the left?
Stan(PA)
07-12-2004 08:02:23
 Re: new owner help. in reply to daniel.b.loyd, 07-12-2004 07:49:21
If the mower deck is a 5 footer, I would guess it's an International C3, or a Woods. Check into both to figure out which one you have.
I'm not sure about the single front, but on most, you can remove the arm from steering box, make sure gear is centered (turn steering wheel lock to lock, count turns, center wheel so same number of turns each way), make sure wheel points straight ahead, reattach steering arm. Now wheel should turn same amount in each direction.
