mag adjustment
Mike
07-11-2004 17:57:48
I have a 1951 WD. It has a new condenser and points and the carburator has been rebuilt. The problem is sometimes it will start right up and other times it turns over several times before starting. The points have been set and reset a couple times, but it still does not want to start properly. I think it may be the mag is not timed properly with the engine. Can someone help me out and explain how to set the mag to the engine? Thanks!
Mike
gene
07-11-2004 23:00:54
 Re: mag adjustment in reply to Mike, 07-11-2004 17:57:48
Since the tractor is running the ignition/magneto timing is close.
The timing marks are located on the back side of the flywheel. You need to get under the tractor. On the bottom of the bellhousing is a small inspection plate that needs to be slid sideways.
Get out the timing light. Start the engine. Loosen the bolts holding the magneto. Rotate the magneto until the "F" for fire is centered in the opening. Thats it.
This operation works well with two people. One under the tractor holding the timing light and the second rotating the magneto - ready to tighten the bolts.
