stalling
Jim
07-11-2004 12:03:38
WD45 stalls under load, starts, idles and revs fine. Any suggestions would be appreciated.
Thanks
Dale(MO)
07-13-2004 05:09:41
 Re: stalling in reply to Jim, 07-11-2004 12:03:38
Jim, Could be your coil breaking down. Have seen this many times in the past. For me, usually if I think it's fuel, it will be ignition. Might be worth checking. Good luck!
Ron
07-11-2004 16:58:04
Well, not sure what you are trying to do with it, but.. If it stalls when put under a good load, and runs good otherwise, it is not getting enough fuel... Are you sure you have the power screw open enough..?? You should be able to open it enough that it smokes black smoke( which is too much)... I always open mine about 1/2 turn for heavy work, and lean it back down for light jobs like mowing... For heavy loads I like to see just a little blck smoke at high idle... If you can't get it rich enough and the fuel flow from the tank is good, then you may need to clean out the bottom passage in the floatbowl that feeds the power valve..
