Carb flooding
Tim
07-10-2004 20:31:38
I bought my C about six months ago, and soon after noticed that gas was dripping from places it shouldn't be, like the hose between the carb and air cleaner. I rebuilt the carb, putting in a new float, and it had been running good since then. Now today I noticed the same problem, after I couldnt get it started. (It is a M-S TSX-154)What do I do? Should I go over the carb again? Would a Zenith carb be better? Which one? Thanks for any help!
steve
07-11-2004 18:25:20
 Re: Carb flooding in reply to Tim, 07-10-2004 20:31:38
either a hole int he float, or a piece of dirt under the shut off valve seat. disassemble and clean again. shake float to see if something is inside.
AZ Jack
07-11-2004 21:37:48
 Re: Re: Carb flooding in reply to steve, 07-11-2004 18:25:20
I agree with Steve. Clean your carb again-put in a good inline fuel filter even if you use it in conjuntion with your sediment bowl. Those old fuel systems and lines are full of crud. No need to change carbs. The MS carb is as fool proof as they come.
