wd info
dipstick
07-10-2004 20:05:21
How do you tell the difference between a wd and a wd 45 if there are no decals or serial numbers? and where are the serial numbers on a wd 45?
CHALMERSBOB
07-10-2004 20:22:53
 Re: wd info in reply to dipstick, 07-10-2004 20:05:21
THE SERIAL # IS ON THE REAR BRAKE HOUSING JUST ABOVE THE ROCKSHAFT, BELOW THE BRAKE COVER. ALSO LOOK ON THE RIGHT SIDE OF THE ENGINE BLOCK, IF THERE IS A BOLT ON PLATE BEHIND THE MAG AND OIL FILTER IT IS A WD. ON THE LEFT SIDE OF THE BLOCK , NEAR THE CARBURETOR AND AIR CLEANER YOU WILL FIND THE ENGINE SERIAL #. IF IT STARTS WITH WD, THEN IT IS A WD. IF IT STARTS WITH 45, THEN IT IS A WD45. BOB
CHALMERSBOB
07-10-2004 20:24:20
 Re: Re: wd info in reply to CHALMERSBOB, 07-10-2004 20:22:53
THAT SHOULD READ, LEFT BRAKE HOUSING. BOB
