AC engine serial numbers
pete
07-10-2004 08:55:04
Seeking any info that is indicated by the stamped serial number on top of the left rear engine flange. The number looks like it is CE701360. The last character that looks like a zero is set away from the others.
ACEd
07-17-2004 18:10:08
 Re: AC engine serial numbers in reply to pete, 07-10-2004 08:55:04
most likely CE 70136 G which would be circa 1948. G indicated Gas as opposed to K = kerosene / distillate (known as tractor fuel) - basic difference is compression ratio.
other option CE 201360 which would probably have a PA suffix meaning later higher compression gas - 201360 would be very late circa 1957. It would be the second highest s/n I have seen (highest was 201833 on a 1957 CA but they made tractors for another year)
CHALMERSBOB
07-10-2004 20:27:39
CE ENGINES WERE USED IN THE B, IB, AND CA AS WELL AS THE C. ALSO ON POWER UNITS AS A CR ENGINE. BOB
Wilson
07-10-2004 10:52:51
CE indicates that it's a Model "C" "E"ngine.
pete
07-10-2004 19:26:20
 Re: Re: AC engine serial numbers in reply to Wilson, 07-10-2004 10:52:51
Thanks, Wilson.
