WD45 Starter not cranking - 6v vs. 12v
Vic Lovejoy
07-10-2004 05:43:25
Hello all. I went out to mow with my WD45 the other day and got some smoke from the starter and very slow cranking. I let it sit for a minute and when I pulled the starter lever it did nothing... no smoke, no noise or anything. The cables are all tight and the battery is charged up. The starter has worked fine for three or four years (since I got the tractor).
So I'm thinking I need to take the starter off and check it out - the only question I have is this: the tractor has been converted to 12 volts. I'm worried that if I install a rebuilt starter (if it comes to that) I'll be putting a 6 volt starter in a 12 volt system and when I crank it it'll blow its brains out or something.
I'll take the thing apart to see if there's any obvious damage like burned wires or whatever, but if y'all have suggestions I would be most grateful. I've got the tractor running pretty well at this point and then blammo no starter. I've tried hand-cranking it but I have tendonitis in my wrist right now and I can't risk re-injuring the tendon.
Any advice would be greatly appreciated.
vic
JMS/MN
07-10-2004 19:28:00
 Re: WD45 Starter not cranking - 6v vs. 12v in reply to Vic Lovejoy, 07-10-2004 05:43:25
Converting a WD45 to 12 volts and using the 6 volt starter is fine- just turns the starter faster, which improves starting. They can blow out no matter what the voltage is- just normal repair.
gene
07-10-2004 14:35:41
I've been running two WD's on 12 volts with 6 volt starters for several years. No problems.
Did have one starter repaired/rebuilt. Cost $60.oo.
Dale(MO)
07-10-2004 06:31:14
Vic, I don't think, unless you started the tractor 20 or30 times a day, that you would have burned it up just because of the 12 volts - I think it was probably getting weak from age. I would take it to a reputable starter repair shop to get it diagnosed. They can put 12 volt parts in it for probably the same price as original. Most of the later (D-series and up) came with the 12 volt starter, so there's no changing to it. Good luck, and keep us posted.
