AC 5040 Questions
Jeff Hull
07-08-2004 21:35:40
I just bought a AC 5040 and I am a little too impatient to wait for my manuels to arrive!
I want to service all fluids before we use it however I must plead ignorant to the workings of this tractor. I have purchased new filters but I have questions. Here are my questions. 1. I changed the engine crankcase oil and filter, 5/w 50 Delo oil and Wix filter. No problems, No questions.
2. The dipstick under the seat appears to have way too much fluid in it, however the dipstick appears to have grinding marks on it. Is this the normal way this thing looks?
3. What type of fluid goes in this part of the cases? Estimated capacity?
4. Where is the drain plug for this case?
5. Under the seat there is a large oil filler cap, you can see fluid down below the gears and misc, however the fluid level appears to be to high to be in the same case as the one where the dipstick is. Is this the same case?
6. Again under the seat and more twords the front, it appears to be another oil filler location. Is this for the P.T.O.?
7. I have found the center section(transmission) drain plug, where is the filler and what fluid do you put in this?
8. Lastly, are there any tricks required to replace and install the hydraulic oil filter?, Fuel filters?
Thank you for your help.
mowr
07-12-2004 07:07:06
 Re: AC 5040 Questions in reply to Jeff Hull, 07-08-2004 21:35:40
Jeff, congrats on your tractor purchase. Just a couple of tips here. One weak point of these has been low oil pressure resulting in engine failure. The "idiot light" doesn't warn soon enough to prevent this. Suggestion: get a technical service manual and a good mechanical oil pressure gauge; then if the oil pressure gets down close to the minimum the manual requires, replace the pump before 'the horse gets out'. Also, they are often slow to get oil pressure up after being started so it's important to start the engine at low speed and leave it there until the pressure is up.
