WD45 power steering unit
kent
07-08-2004 18:59:21
Dave, I rebuilt the unit tonight. i put it back together and it must be out of time. when you start to turn the wheel to the left, it jerks violently to the right. if you try to turn right, it turns violently to the left! I'm sure that the body is in time because it has a paint line on it that can't be mistaken. i forgot to line the shafts up as you stated so maybe that's the problem. the output shaft is a gear on the inside and it's symetrical meaning you can turn it any way you like....so i'm not sure if i move it what good that's going to do. i'm sure i'm missing something here. Do you have any more advice or anyone else? i would appreciate it very much. I can't figure this one out. Thanks, Kent
Dave Grubb
07-09-2004 05:57:03
 Re: WD45 power steering unit in reply to kent, 07-08-2004 18:59:21
You are out of time all right. Set the output shaft keyway in the same plane as the the input shaft keyway by repositioning the gear teeth at the gerotor end. Keep us posted.
kent
07-09-2004 09:39:58
 Re: Re: WD45 power steering unit in reply to Dave Grubb, 07-09-2004 05:57:03
Dave i will do this tonight. thanks very much!! by the way, there was a typo in your reply that I don't understand...it was "gerotor". what did you mean by that? it would help me understand this better. thanks so much. Kent
Dave Grubb
07-09-2004 14:02:54
 Re: Re: Re: WD45 power steering unit in reply to kent, 07-09-2004 09:39:58
Not a typo. It is a type of oil pump or hydraulic motor. The other main two types are the gear and the piston. The hydraulic pump on your tractor is a piston style pump. Most later model tractors and such use a gear style pump for hydraulic pressure. The engine oil pump in your tractor is a gear style pump.
kent
07-12-2004 07:34:52
 Re: Re: Re: Re: WD45 power steering unit in reply to Dave Grubb, 07-09-2004 14:02:54
Dave, I still didn't get it right. I'm going to try to get the assembly diagram from char lynn. i hope that's possible. i can turn the keyways to get them lined up but on this pump, i don't think it's still right because the one shaft is separate from the gears. it's hard to explain via email but i can turn and line up the keyways but it doesn't affect the way the gears are turned. Kent
kent
07-10-2004 09:31:44
dave, thanks. i'm working on it this morning. i'll let you know.
