allis wd
kevin walker
07-07-2004 19:07:53
anyone know how to split a wd at the engine ???
kevin
07-08-2004 17:37:21
 Re: allis wd in reply to kevin walker , 07-07-2004 19:07:53
sorry i geuss i didn't explain my self well enough i want to split the tractor between the motor and tranny and there is a shaft in the that runs though that i can't get apart to split it
JMS/MN
07-08-2004 17:55:50
 Re: Re: allis wd in reply to kevin, 07-08-2004 17:37:21
If you have the engine out, you mean the shaft that runs forward of the tranny, through the clutch and into the flywheel? It also runs the hydraulic pump and belt pulley? I have one in the shop now, split at the hand clutch, with those two front castings just pushed forward. I'm thinking there are some covers to remove that expose snap rings that hold that shaft in place. Pulled one apart this winter to get oil clutch parts. I'll check the castings in the shop tonight and let you know.
JMS/MN
07-14-2004 08:02:14
 Re: Re: Re: allis wd in reply to JMS/MN, 07-08-2004 17:55:50
You need to unbolt and remove the transmission clutch- the one that runs in oil. The shaft you refer to is the input shaft to that clutch, and there is a snap ring at the back end to remove. Bump that splined coupler off and the shaft comes out forward. You might need to pull the clutch housing casting off the front first, also remove the hydraulic pump so the lobes on the shaft can clear the pump plungers.
JMS/MN
07-07-2004 22:12:01
Remove the hood. Remove the radiator. There are two 1/2 inch bolts inside the C-channel that hold the radiator in place. Remove the bracket and spring on the crank assembly. Remove the wiring harness from the engine. Remove the front engine support. Remove the sheet metal cover in front of the clutch assembly. Remove the throttle control rod. Remove the gas line between the gas tank and the carburetor. Remove the hose between the air cleaner and the carb. After you suspend the engine with your hoist, remove the four bolts that hold the engine to the clutch housing. Remove ron. Pull the engine forward and up to remove it from the clutch housing. The side frames of the tractor provide a good base to use for rebuilding the engine.
Ron
07-07-2004 21:26:20
Why..?? Just remove the engine...!!
Test
08-22-2004 04:43:47
 Re: Re: allis wd in reply to Ron, 07-07-2004 21:26:20
test
