WD hydraulics
Mark A
07-07-2004 05:16:16
I have an AC WD with the single hydraulic outlet under the seat. I understand the control for the outlet is the same as for the power lift. How do I switch from one to the other? Do I have to change a knob or setting to divert power from the lift to the outlet, and then back again? Any help is greatly appreciated. Thanks in advance.
Mark A
07-08-2004 06:41:53
 Re: WD hydraulics in reply to Mark A, 07-07-2004 05:16:16
Thanks everyone. Just got this tractor, and my brother is working on this at his house, and calling me. I think I now know how it should work. I was hoping to be able to use the remote independently from the lift arms, by switching a valve or setting. Since I dont have a manual for it yet, I was wondering how the hydraulics work. Thanks again.
Barry Coble NC
07-07-2004 19:51:49
Mark;
The remote coupling is live with the lift arms and needs no "switching over" to use. Simply attach your hose and raise the lever on the quadrant and the ram will raise the implement. By the same token, lower the lever and the implement will lower as well. If your hydraulics are in good shape you can even "hold" the ram in a certain position with the control lever. A slight delay is normal while the lift arms raise, then the oil flows to the remote. If you have a lot of delay or the remote doesn't work at all, you may have "Transport Valve". This is a small rectangular box with a knob that the remote coupling attaches to. Open the knob fully and the oil should flow normally. Hope this helps.
acorange
07-07-2004 13:46:37
I put small ball valves in the line to each cyl.
on my WD for this reason.
You can get them at any NAPA or Farm-Fleet type store.
DanD.
07-07-2004 05:45:53
One the lift arms raise, then oil will flow to the outlet.
Mark A
07-07-2004 09:02:38
 Re: Re: WD hydraulics in reply to DanD., 07-07-2004 05:45:53
What about if I want to flow through the outlet before I lift up the lift arms?
JMS/MN
07-07-2004 12:18:12
 Re: Re: Re: WD hydraulics in reply to Mark A, 07-07-2004 09:02:38
It's an either/or situation, but you could install shutoff valves in the lines to the cylinders. Or tie up the arms to prevent them from lowering, and save the up time each time you activate the control.
