Allis Chalmers C Oil. How Much, What Kind, Where A
CWCHALMERS
07-06-2004 13:13:39
My Neighbor just recently gave me an Allis Chalmers C Wide Front End and I was Wondering what kind of oil to put in the engine the final drive the transmission and anything else that takes oil. I would also appereciate it if someone could tell me where it goes and where to check it at all of the places mentioned.
Thanks Very Much, CW
steve
07-06-2004 15:40:00
 Re: Allis Chalmers C Oil. How Much, What Kind, Whe in reply to CWCHALMERS, 07-06-2004 13:13:39
put 4 quarts of 10w30 motor oil in engine. drain trans, pto and steering thru 3 pipe plugs under the common trans- bevel gear area. refill with 8 quarts of 20wt hy-trans universal trans fluid from Wal Mart or Farm Store. Fill by your left foot thru 1 inch pipe plug.--- final drive is under the bottom end inside the wheel area. takes 2 quaarts of 90 wt gear lube in each, but you need to remove the cover to clean and drain.
TexasAllis
07-06-2004 14:25:02
Try this site. Good info.
http://people.clemson.edu/~wsmth/
