WD Narrow Front Slop
Mike IA.
07-06-2004 06:38:28
Is there any way I can tighten up the front end on my WD? Going down the road wide open the front starts to shimmy (gets kind of scary) especially down hill. Any insight would appreciated. Thanks in advance.
Gordon in IN
07-07-2004 18:12:23
 Re: WD Narrow Front Slop in reply to Mike IA., 07-06-2004 06:38:28
Mike, If it looks like the "slop" in in the gear, it may be a problem with the tapered set screw and lock nut that holds the gear to the vertical steering shaft. To check this, first loosten the lock nut on the set screw. Then tighten the set screw (very tight) and then retighten the lock nut. The set screw has a tapered point that fits in a tapered hole in the shaft. The point of the setscrew or the tapered hole in the shaft may be worn if the set screw was loose for a long time. I have never seen a WC, WD, or WD 45 with the steering "worm" and "worm wheel" gears worn enough to be a real problem. There may be some out there somewhere. I think the problem is usually elsewhere.
Dave in Mo
07-07-2004 09:37:57
More likely than not the slot that holds the key itself is wallowed out. The key is hardened steel and won't wear but the shaft is soft. I used shim stock to take out sideplay and it works. Assembly is tedious.
Bill(Wis)
07-07-2004 06:04:17
The set screw located at the lower front holds a key in it's slot on the bottom end of the sector shaft. The slop you mentioned sounds like it might be coming from there. Remove one front wheel and then remove the cap from the bottom of the sector shaft. Loosen the set screw and remove the key. Check key slot for wear. Replace key with a new one, tighten set screw. If you let that slop go too long you will risk wearing the key slot. That may already have happened.
Barry Coble NC
07-06-2004 20:01:42
Mike;
If all else fails, try running more air pressure in one tire and take some out of the other to make it "pull" a little. It's not scientific and certainly not a fix, but it works temporarily until you can make the repairs.
Ron
07-06-2004 10:00:29
Is the slop at the bottom, at the "Set screw", or at the sector/shaft key..?? ( at the top of the shaft)...?? Is it slop in the gear..?? I think the 1st thing I would check is wheel bearing adjustment, then the set screw at the bottom of the pedestal.. Myself, I set bearings to a light pre-load..not the recommended "1 flat loose".... Tapered bearings make proper contact only when they stay aligned, and pre-loaded is the only way they stay aligned...is some situations, that means "at operating temperature"....so that must be taken into consideration.. Let us know what you find... You need to "pin down" where the slop is first..!! Ron.
Mike IA.
07-06-2004 10:19:33
 Re: Re: WD Narrow Front Slop in reply to Ron, 07-06-2004 10:00:29
I jacked it up and it looks like it's in the gear.
JMS/MN
07-06-2004 12:25:36
 Re: Re: Re: WD Narrow Front Slop in reply to Mike IA., 07-06-2004 10:19:33
Also check for worn pins or bolts in the u-joint, the cross in the joint, and the tapered bearing at the bottom or the pedestal. If it has a 'scalloped' surface, it can make the wheels wobble, especially on a hard-surfaced road.
