Hydraulic leak!!!!!!!!
Scott
07-05-2004 18:39:06
Need help just took the lift arm housing off my 190xt to replace the seal that was bad. When I took out the pto shaft all the fluid drained out(about 15gallons) After putting new seals in and getting everything put back on I went to refill the fluid. Checked both the trans. and hydraulics and they were out. I put about 8 gallons in both of them. Now when I drive the tractor fluid comes out the right side where you put the fluid. The tractor also has a bad pause before it starts to move also. can some tell me what Ihave done wrong. thanks Scott
