What size front tires should be on a D-14???
Eric Allen
07-04-2004 22:31:46
Any one know? Would they be the same as any other tractor? Thanks
ACEd
07-17-2004 18:25:11
 Re: What size front tires should be on a D-14??? in reply to Eric Allen, 07-04-2004 22:31:46
5.50-16 for tricycle; 6.00-16 (possibly 6.50-16 optional but I doubt it based on my D15 book) for wide front. Industrials may be larger of these, but doubt any ever had larger than 6.50-16. Expect stock rims only about 3.5" or 4" wide
John (MO)
07-07-2004 06:21:56
Check the rim width. You won't have good luck with a 7.00 tire on a 5.5" rim. Use tires that pretty much match your rim width, whatever it is. The D-14 likely left the factory with 5.5" rims, but that was a long time ago, things could have changed by now.
Kevin
07-05-2004 19:17:19
the tires should be a 6.50 or a 7.00
Kevin
07-05-2004 19:00:57
CHALMERSBOB
07-05-2004 19:39:45
 Re: Re: What size front tires should be on a D-14? in reply to Kevin, 07-05-2004 19:00:57
MY OPERATING INSTRUCTION BOOK FOR THE D14 STATES FRONT TIRE SIZE AS 5.50X16. REAR 11X26 WITH OPTIONAL AS 12X26. BOB
