WC oil pressure (or lack of)
Kent Fedor
07-04-2004 21:18:49
Just bought myself a really nice old "original" '37 WC. after fixing the carb float, fires up and runs nice...problem is practicaly no oil pressure. Put a new (tested) gauge on it and it shows maybe 1lb oil pressure cold. Pulled off the oil release-valve on the side of the block, no difference. Currently has a newer Agco oil filter on it. I really find it hard to believe this engine is so loose that I have no oil pressure...sure it's a worn engine...but I don't think worn enough to have no oil pressure. Any thoughts or tips would be appreciated. Thanks & God Bless, Kent Fedor
Bill(Wis)
07-05-2004 15:07:57
 Re: WC oil pressure (or lack of) in reply to Kent Fedor, 07-04-2004 21:18:49
Kent: I recommend you read the post below entitled "WD Oil Filter". WC has same oil filter as WD..
