WC early 40s timing
Roger S
07-03-2004 21:53:55
I am rebuilding a WC I bought cheap because the engine was locked up. THe engine is back together now. I am trying to set the timing, but the service manual might as well be in Greek. The tractor was converted to 12 volt battery start, and the manual refers, I believe, to magnetos and such. I found the F mark on the flywheel, but setting the distributor is a mystery. Any help would be much appreciated. If it would help, pics are at Link
Gene
07-04-2004 10:57:30
 Re: WC early 40s timing in reply to Roger S, 07-03-2004 21:53:55
Rotate the engine until the #1 cylinder is on the compression stroke. Get the "F" within the viewing plate under the bell housing. Now take a look at the pulley for the water pump/fan/generaltor/alternator. The bolt and nut holding the pulley on crankshaft should at about 10:00 o'clock position. Slowly rotate the engint until the nut/bolt is at the 12:00 o'clock position. This at or very near TDC. Time your distributor. Engine should be set close enough to start. Using a timing light you can fine tune the engine using the "F" (advance) timing mark.
Duey (IA)
07-04-2004 07:25:33
Roger,
Steve is correct in that TDC is used for static (engine not running) timing a dist. "Fire" is used after it is running and you are using a timing light.
steve
07-04-2004 06:26:59
Roger, basically you set the crank at the fire mark, but you need to be on the compression stroke, not the exhaust stroke. to do this, take out the spark plugs and put thumb over the front cylinder hole whilce rolling motor slowly. you should feel compression on thumb when valves are closed and you are coming up on the compression stroke. then set the crank at the fire mark.---- at this point the point in the distributor should start to open and you should have the distributor top arm pointing at the #1 spark plug.---- if not. move the distributor each way untill the point starts to open, or pull the distributor up a couple inches, rotat and reinstall so the gears engage at another point so you are pointing at the #1 plug and point starting to open.--- im not sure which distributor you have. if it has advance weights, you might want to be opening closer to TDC so that after it starts you get advance to the "FIRE" mark.
