sleeves
jared
07-03-2004 14:55:07
i got 1 out with a block of wood and hamnmer, 1 move a bit up less than 1/4 inch and the other2 won't budge, any ideas? tips?
jared
07-05-2004 08:58:21
 Re: sleeves in reply to jared, 07-03-2004 14:55:07
the metal bar is a good idea but I can't remove the block, I don't have a lift
steve
07-05-2004 10:22:23
 Re: Re: sleeves in reply to jared, 07-05-2004 08:58:21
get a long piece of all thread, maybe 5/8 iinch. put a flat bar on the bottom that spans the liner. might have to be extra thick for no bow. put a big plate on the top with a hole in the center for the althread. block it up a couple inches with 2 x 4 on the side. tighten the nugs on althread and will lift the liner.
Dick L
07-03-2004 15:12:41
You could use a sleeve puller, But I would swithch the block of wood for a steel bar and get a bigger hammer. It takes such a short time to pull the engine that I turn an engine upside down on two 6"x 6" blocks of wood and drive them out with a 1"x 2"x 24" bar of steel and a sledge. The job of removing the sleeves takes minutes that way.
