1938 AC Model C Flywheel and PTO
Anthony
07-03-2004 13:36:22
I am looking for a flywheel for a 38 model C flywheel. I found someone a while back but lost his email. I think his address started with castr... Also, my pto has an "adapter" on it to size it up and the previous owner had it attached with a bent over nail. The hole is now rounded out on both the pto and "adapter". I run a 60" woods brush hog (pull behind) and it really raps when I made a turn. I was wondering if the play in this pto/adapter would cause this. Thanks
Dick L
07-03-2004 15:00:34
 Re: 1938 AC Model C Flywheel and PTO in reply to Anthony, 07-03-2004 13:36:22
Ya gots a tough job a heada ya. They started makin C's in 1940.
The differences in the flywheels would be if it was made for a ring gear or not. Older models of C's and B's all had 8 1/2" clutch, newer models of both B's and C's had 9" clutches. Bolt spacing is different for the pressure plates. A flywheel that had a ring gear will work on a crank start and if you get the flywheel with the 9" clutch and pressure plate, it will work on a 1938 B.
