WD Oil Filter
Illinois
07-01-2004 18:27:17
I think I can remember the WD tractor my Dad had, in that the oil filter base had a three or four inch long spike thing that inserted itself into the oil filter when the filter was installed.
And the filter was made up of shredded string.
Am I remembering that correctly, that was fifty some years ago, and I can`t remember for sure. If so, are the filters still made that way, or were there some kind of adapters available to use a newer design filter?
Steve in N.J.
07-04-2004 18:39:41
 Re: WD Oil Filter in reply to Illinois, 07-01-2004 18:27:17
We carry the correct filters in stock for AC machines. We have the Fram C-159's. We also have a replacement oil feed tube which runs up the center of the filter mounting base. We still have our filter special going. Drop us a line if interested....
Steve/B&B Custom Circuits
RA ec ia.
07-05-2004 17:49:52
 Re: Re: WD Oil Filter in reply to Steve in N.J., 07-04-2004 18:39:41
I checked out a Fram c-159 today at a local farm&home store. It did NOT have the wood dowel up the center, and it didn't look like it had the same type of filter material as the old ones had.
It may still work ok, but it isn't like the old ones.
wdTom
07-02-2004 17:53:30
Some of the filter makers have changed the design and it won't work, it will reduce the oil pressure in the engine. If you go to buy a filter and it doesn't have the wood dowel and yarn visible above a perforated metal plate on the bottom, don't buy it, look else where. You don't want one of the "new impeoved" ones. They are probably cheaper to make or something so that is why they changed what has worked for 70 years.
John in S. IN
07-03-2004 15:29:31
 Re: Re: WD Oil Filter in reply to wdTom, 07-02-2004 17:53:30
I just bought a 53WD and it has a spin on filter. Is this something I should be concerned about? jdoofus -at- hotmail.com
Paul
07-02-2004 16:19:40
Yes they are still made that way. I have a 1947 VAC Case that uses the same kind. I have never had trouble finding one
Illinois
07-01-2004 18:59:25
Thanks a bunch guys, thought I remembered the spike shaped thing, but like I said, it's been 50 years or so since I have seen one. Can`t hardly believe they still make filters that would fit it.
Thanks again...
Barry Coble NC
07-01-2004 18:54:03
Yes--the filters had yarn in them, Illinois. The ones you buy today still are still made that way, and they come with a removable wooden spike in them that you take out when you install the filter. This leaves a hole for the tube on the tractor's oil filter adapter.
Illinois
07-01-2004 18:43:57
Thanks... Is it still the same long spike-like thing that pierces the oil filter?
bw in mo
07-01-2004 18:34:25
Yes they make the filter , the # of fram is C159.
