Gleamer engine in WC ?
rhudson
06-30-2004 12:53:19
Ok so got a few questions, the gleamer engine has only one lever on the governer, the WC has a hand throttle input and a governer output that goes to the carb. the port for the hand throttle on the gleamer governer is plugged. can i knock the plug out and put the wc governer parts in the gleamer governer. all this is to make a pulling tractor for my son. Thanks for any help.
DanD.
06-30-2004 14:06:25
 Re: Gleamer engine in WC ? in reply to rhudson , 06-30-2004 12:53:19
Just remove the entire governor and the housing from the WC and put it on the GleaNer engine. Then everything is there how you need it. Also need to use the WC water pump and flywheel.
