Water in oil bath air filter
U.P.Pete
06-30-2004 07:52:45
Hey Guys,
My '48 C started running rough. Slight miss, surging, no power, etc. Checked the obvious such as plug wire, etc. and found the oil bath filled with a milky oil/water mix. Cleaned it out and filled with fresh oil. Could this be part of my problem? If so, what's the cure? If not, what to look for? Thanks in advance for any info you might have..... ..... Pete
Dave Grubb
06-30-2004 08:58:13
 Re: Water in oil bath air filter in reply to U.P.Pete, 06-30-2004 07:52:45
This is a normal thing if you don't service the unit often enough. The water is just condensation; presuming you have the weather cap on the unit. It is possible to have the air so 'wet' that you will get ice in the carb and cause your problem. The air temp will drop about 30 degrees as it passes thru the venturi of the carb and that can get the temp down to freezing.
