allis WD?
casey
06-30-2004 06:39:18
i have a chance to pick up a WD. just wondering how many horses it has? more of a red man here. just looking for something small to mow road ditches with and this WD is cheap. thanks
Bill(Wis)
06-30-2004 21:08:56
 Re: allis WD? in reply to casey, 06-30-2004 06:39:18
If you're talking a sickle bar mower it will work great. A rotary Bush Hog type mower will be a load for it from the stand point of weight. The tractor is 6 feet wide and if you want to cut 6' wide the mower you get will weigh in at 800-1000#. That will bring the front end up going uphill. Adding weight on front end of tractor will fix that. Just so you know. Also the tractor will need a 3 point hitch.
Phil Auten (TX)
06-30-2004 07:31:08
About 30 on the drawbar, 35 on the belt pulley.
Should make a great mowing tractor.
Phil
