Allis Chalmers CA
Ed-Sal
06-29-2004 12:55:20
I am looking at a 1953 CA. Was the CA a very good tractor? What are the bad points of it? It has a wide front with snap coupler. Tires are just fair-have good tread but cracks.for some unknown reason the end of the pto shaft is broke off. Would that cost a lot to fix? Is there anything about the tractor I should look for?
cmarlin66
08-09-2004 17:22:38
 Re: Allis Chalmers CA in reply to Ed-Sal, 06-29-2004 12:55:20
be sure you can get a pto shaft i have been looking for about 8 months
no luck yet
Daniel Dulmage
07-02-2004 13:49:23
I love my CA. They are an excellent tractor and can do a lot of work.
wdTom
06-29-2004 18:31:29
What to look for, well other than the usual, check the shift lever boot, if it is missing or cracked water can get into the transmission. If all works water is not the end of the world, just drain and refill it.
Dick L
06-29-2004 14:25:07
The CA is a very good tractor. I loved to plow with mine pulling a 2-14 snap couple plow in hard clay. If you can do the work your self the power takeoff shaft would not be a big cost. If you can't, I would call your local tractor repair shop and get a quote.
