WD45 wiring with alternator
Brad Rising
06-29-2004 07:42:27
I need some help gentlemen, I have a wd45 with a single wire alternator that someone previously had installed, the charging system works fine, but it has never had the ammeter or lights hooked up, just wondering if there is a schematic or wiring diagram that will show me how to rewire the system. I have found the 6v generator wiring schematic, but I want to make sure I am wiring it correctly for the 12v alternator configuration I have now. Any help would be greatly appreciated, also I am looking for a set of headlights and brackets to install on it, I will need a headlight switch etc. The alternator wire now just goes to the positive battery terminal, and I assume it would have to go to the new ammeter, then to the battery.Thanks, Brad Also, one other thing I noticed is that one of the front wheels is mounted with the dish part of the wheel out and the other is mounted with the dish part on the inside?
Keith-OR
06-30-2004 23:21:54
 Re: WD45 wiring with alternator in reply to Brad Rising, 06-29-2004 07:42:27
check out this website. Go down to #35, one of the diagrams should fit your needs.
HTH..... Keith
http://albums.photo.epson.com/j/AlbumList?u=4001561h
Brad Rising
07-05-2004 14:07:30
 Re: Re: WD45 wiring with alternator in reply to Keith-OR, 06-30-2004 23:21:54
Thanks for all the help guys, Keith the website you sent me is no longer available, but I think I have enough to go on, thanks again all, Brad
Phil Auten (TX)
06-30-2004 07:35:46
Check here. Duey has provided diagrams for just about every possible setup on a tractor. The diagrams are generic. Bookmark the page so you can find it again.
Phil
steve
06-29-2004 16:16:02
the alternator wire should go to the amp meter. the other side of othe amp meter goes to the + terminal on the battery. the starter is connected to the battery side of the ampmeter so the swithc does not show amps while cranking. the lights and anything else connects to the alternator side of the amp meter so that the lights show a discharge on the ampmeter, if the motor is not running. i have a simple diagram with a 2 pin alternator, just an extra hot wire. if you need a simple drawing- send e-mail --- [email protected]
