Allis Chalmers WD or WD45
Bennie Fincher
06-26-2004 15:55:22
I bought a very old tractor. I need to know how to find the model #'s and the year and make. Any advise would be appreciated. Engine # Right side RS U30 19-31-7 Left side WD30 14 95 PA, Transmission in front of straight gear shift 0-1-KC under that shows 200931, with a 6 stamped in. On the rear end AM-36-35-7114 F19.
John (C-IL)
06-26-2004 18:10:22
 Re: Allis Chalmers WD or WD45 in reply to Bennie Fincher, 06-26-2004 15:55:22
The engine serial number WD301495PA tells you that you have a WD assuming no one has switched the engine, You will find the tractor serial number on the rear, left of the differential cover on a flat spot between the brake spring hole and the brake adjusting bolt. From that number you will be able to dtermine the year.
Bennie
06-28-2004 18:25:01
 Re: Re: Allis Chalmers WD or WD45 in reply to John (C-IL), 06-26-2004 18:10:22
John,
Thanks for your response.
I've looked at several other tractors in this location, this tractor has no serial# stamped there.
Any other suggestions??
Thanks,
Bennie
