Solenoid?
Rebecca
06-22-2004 09:43:29
We have an Allis D17 that we were just using to pull small shrubs out of the yard. At one point we stopped and turned the tractor off to load up a wagon. When we tried to start it again all we got was a click. It was running great up to that point. I've heard that the solenoid will not make any noise if it's bad but we are hearing a click that seems to be coming from that area. We've charged the battery to full charge and still only a click. Could this be the solenoid? Any other ideas?
Rebecca
06-22-2004 20:02:29
 Re: Solenoid? in reply to Rebecca, 06-22-2004 09:43:29
Wow, thank you so very much for the quick responses and taking the time to post them. It's great to have such wonderful help out there. Hopefully we can get Allis working again soon. Thanks again!!
Dale(MS)
06-22-2004 14:49:20
Rebecca, Might remove the bolt and lock nut that holds the starter in its place. Then with a screwdriver or something move the starter back about a 1/4" and see if you here a click. If so then move the starter forward and replace the bolt and lock nut and try to start.Sometimes you can rock the tractor in gear and it will break free. Good luck! Dale
Steve in N.J.
06-22-2004 14:44:57
Becky,
It could be as simple as a loose or dirty connection. Disconnect the ground or starter cable from the battery, then disconnect the battery cable from the starter solenoid. Clean up the cable eyelet real good and reinstall. If it still clicks, go to the grounding cable at the frame rail and clean that connection and try. If it still just clicks, it could possibly be the solenoid itself. It's usually the dumb things that make you scratch yer' head...Good Luck!
Steve/B&B Custom Circuits
Brad W Wi
06-22-2004 11:04:35
A solenoid will make noise when its going bad, especially a clicking sound. Try tapping it somewhat hard when its clicking. It might release it.First make sure your battery is good and connections are clean and tight.
