Straight Pipe for WD-45?
Martin Miller
06-21-2004 18:32:56
I would like to get a straight pipe for my 1955 WD-45. Does anyone know where I could buy one? I have always been told that a straight pipe will damage a motor but I have also heard that it wont hurt the motor a bit. I would appreciate any help.
dupontsniper
06-25-2004 07:45:16
 Re: Straight Pipe for WD-45? in reply to Martin Miller, 06-21-2004 18:32:56
They say loud pipes save lives, but I usually dont go that fast on an Allis! Straight pipes are great! (for a short time). ? didnt catch that, say someting?
acorange
06-23-2004 06:43:21
For awhile I had a straight pipe on my WC...
It got very annoying while mowing so I went back to a muffler.
I like my hearing a lot more than the sound of an unmuffled AC.
Eric Allen
06-22-2004 23:27:01
We have a glasspack on ours and it runs just fine, sounds cool too, sounds like a big pulling tractor...
Jim
06-22-2004 19:48:08
I like to use stainless milk line pipe. It looks nice and wont rust It also has a better sound than a regular piece of pipe.
wdTom
06-22-2004 18:15:24
A certain size of electric conduit will fit, well it fit the new manifold I bought anyway. Then weld on a bracket to bolt it to the manifold. It might sound good, but after listening to it for a while are you sure you don't want a muffler?
Eric in VA
06-22-2004 07:13:19
I would run striaght pipe if I had a WD 45. But all I have is a "C" and I have straight pipe on it!
Don't put chrome pipe on it because it will turn different colors after it heats up and cools down! You dont really need chrome pipe if it isn't a show tractor.
Steve in N.J.
06-22-2004 14:38:11
 Re: Re: Straight Pipe for WD-45? in reply to Eric in VA, 06-22-2004 07:13:19
Ahhh, but you CAN install a Chrome pipe. You just don't use it for your main exhaust pipe. I have a straight pipe on my B, and it seems to run fine. I also have a chrome stack pipe which I slid over the "real" exhaust pipe which is in the manifold like the OEM muffler slides in. The chrome stack I have on the outside which is held in with the bolt which threads into the manifold. The bolt serves two purposes. Holds the chrome pipe and snugs up against the inner exhaust pipe to keep that tight also. I did that revision about 2 years ago, and they are both still nice n' tight. Best part about it is.. no colors in the chrome!
I guess it's just the "hotrodder" comin' out in me... LOL!
Steve/B&B Custom Circuits
Eric in VA
06-23-2004 08:35:38
 Re: Re: Re: Straight Pipe for WD-45? in reply to Steve in N.J., 06-22-2004 14:38:11
Steve,
I know what your talking about when you put the chrome stack over the OEM exhaust pipe. I have a friend that did that to his B. It looks sharp. Im thinking about doing it to my C! What size chrome pipe do you have? I have a 1.5" diameter straight pipe on the tractor!
I just didn't want Martin to go and buy a chrome pipe and then be upset because it turned colors and we didn't tell him!
ERIC
Steve in N.J.
06-23-2004 15:12:21
 Re: Re: Re: Re: Straight Pipe for WD-45? in reply to Eric in VA, 06-23-2004 08:35:38
Hi Eric!
If memory serves me correctly, I believe I used a 2.5" chrome pipe to cover the 1.5" exhaust pipe. This gave it some air space in between the pipes. It worked out pretty nice. One of the fellows mentioned a glass pack. That was the next thing I was working on and putting a 3" chrome pipe over that to give it a better sound....
Steve@B&B
Eric in VA
06-24-2004 11:25:34
 Re: Re: Re: Re: Re: Straight Pipe for WD-45? in reply to Steve in N.J., 06-23-2004 15:12:21
Steve,
Thanks for the deminsions! What are you putting a glasspack on?
ERIC
Ron
06-21-2004 19:24:15
Cut one out of an old driveshaft tube, and weld a bracket on it...!!
Dad ran his for 20+ years with a straight pipe and it never hurt it..I ran a muffler...they both pulled the same..4-14" semi-mounted plows in ANYTHING...7" Deep.. You could always see when he got to the far end of the field..( A Half-Mile away)-- there would be a 3 to 4 ft flame rise up from that pipe when he closed the throttle, as the plow came out of the ground...!! A 6" BLUE Ball of flame would be over-top of the pipe, anytime it was running at full throttle..!! Made it easy for him to light his cigars..!!
tim[in]
06-22-2004 05:09:09
 Re: Re: Straight Pipe for WD-45? in reply to Ron, 06-21-2004 19:24:15
i take it you didnt run a mounted picker on it or bale straw? lol i drove two diesels for a farmer for years with straight pipes. sounds awesome!
