AC 5040 Lift
marilyn draughn
06-21-2004 11:09:40
We are having problems with the front and back lifts on our tractor. The front lift will not come up at all and the back one will move up and down, but when you put a piece of equipment on it, it will not lift. We have taken the hydraulic system apart and cleaned it. Any suggestions on how to fix this or what we can do? Also, what about repair parts? We can't seem to find a lift kit for the hydraulic system.
Thanks for your help.
simon
06-24-2004 17:21:16
 Re: AC 5040 Lift in reply to marilyn draughn, 06-21-2004 11:09:40
Sound like you have a hyd pump problem did you check your hyd pressure on your hyd pump you should have atless 2000lb pressure with 8gpm flow check it out first if you more question let me know or call 613-678-3888
