WC questions, how is the traction?
RedandGreen
06-20-2004 21:20:37
was wondering how well will a WC pull a pullbehind plow such as 2-14's compared to tractors like a farmall H that has bigger tires? I guess in general I'm wondering how is the pulling power? also can a WC run a Forage harvester from the same time periode of the WC?
Gordon in IN
06-21-2004 19:00:55
 Re: WC questions, how is the traction? in reply to RedandGreen, 06-20-2004 21:20:37
Traction depends a lot on the size of tires you have, if they are "fluid filled" and if you have wheel weights and front end weights. I friend of mine has a WC with rather narrow 24" tires (I do not know the actual size/width)on pressed steel wheels, with no "fluid fill", no wheel weights, and no front end weights. Even with a very "tired" worn engine about all he can do when he really needs to "pull" something is "spin, spin, spin". One of my WC's has 12.6 x 28 inch tires on steel rims with cast iron centers and no fluid and no wheel weights. It will pull a lot that my friends WC will not pull. My other WC has 14.8 x 28 inch tires on steel rims with cast iron centers, wheel weights, "fluid filled" tires and front end weight. It will pull a 3-14 IH Plow Chief pull type plow (but even with a high compression 1/8 inch over bore sleeve set in the engine and in excellent condition it does not have enough power to pull it very fast). This tractor will pull a 10 foot tandem wheel disk very well in third gear. Wider tires and more weight on the wheels helps, but you still have to have enough power. If you go too far you just wear out the tractor (or break something) faster. Good luck
Rich
06-21-2004 14:56:33
We used to pull a New Holland 616 chopper, with forage box behind with no problem.
acorange
06-21-2004 14:41:22
A WC that is in any shape at all will pull a 2/14
plow uphill and down. The key is ballast.
While having fluid filled tires is good, I have
found having 2 100lb. plate weights on each tire
is the next best thing. Another thing that also
helps but is a pain to set up is putting some
weight on the front end.
My 2 cents...
Gene
06-21-2004 08:30:38
Plowing should be no problem with the WC.
The big problem with the WC is in the operation of PTO driven equipment. With the PTO engaged the tractor and the PTO driven machine start at the same time. When you hit a slug of hay or forage you have to stop the tractor, disengage the transmission or the differential (depending on year and how equiped) and let the machine clear.
Also you have to watch your turns. When you push in the clutch the PTO driven equipment continues to drive the tractor forward.
One of the models later than the WC would be a better general purpose tractor. Starting with the WD you get hydraulics and two clutches. One clutch can be used to bring the PTO operated machine to operating speed and the second clutch controls the forward motion of the tractor.
Sid
06-21-2004 07:33:10
The WC should handle the plow but in my opinion it is a little light without loaded tires. I remember some around here pulled choppers with Wc's but it was a load.
JeffC
06-21-2004 04:23:50
While I don't have any personal experience with an H, the general consensus seems to be that a WC will do everything an H will do and more (assuming loaded tires). A 2-14 plow should not be any problem under most any conditions short of heavy clay and alfalfa.
