Timing marks on WC
UUsee
06-20-2004 20:34:10
Trying to time my 39 WC. Bell housing has 3 holes to view the flywheel,and 2 Fs on the flywheel.From front of tractor looking back the holes are at 10,8 and 4 oclock, What goes where????? ?????
Gene
06-20-2004 22:42:07
 Re: Timing marks on WC in reply to UUsee, 06-20-2004 20:34:10
You need to remove the inspection cover from the bottom of the bellhousing to observe the timing marks.
Trick. When the bolt holding the belt pulley to the crankshaft is at 12 o'clock the flywheel is at or very near TDC. The engine may on the compression stroke or 360 degrees out.
Turn the engine over slowly until the bolt is approaching TDC. Get under the tractor and look for the "F" stamped into the flywheel. Turn the engine until the "F" is center in the inspection hole. This will be 30 degrees before TDC.
Check to see if one of the two "F"s is showing through one of the three holes.
On my 36 WC someone painted a "F" on the flywheel that can be seen by removing the plate (belt pulley gear housing cover) on the top of the bellhousing. This "F" lines up with a hole in the center of the bellhousing. Sure saves a number of trips under the tractor.
