WC aux tranny
justin
06-20-2004 18:17:07
can someone give me some info on these. i have one on a parts tractor. anyone have pics? what are they worth?
dan wc ne wyo
06-22-2004 21:24:11
 Re: WC aux tranny in reply to justin, 06-20-2004 18:17:07
Hi Justin, take off the aux. trans.shift cover and mark the top rear on a gear tooth ,main trans in N and 1 rear wheel off the floor. Turn the wheel and count the teeth on the top rear gear 20 T is under or step-down, 15T is over or step-up. I bought an incomplete step-down trans. from Larry Swenson in Minnesota a couple of years ago and I think he told me he usually gets around 500 dollars for a complete one including adapter plate mtg. bolts, shifter,and bearings. Long post,sorry. HTH Good Luck Dan WC ne wyo
Gordon in IN
06-21-2004 19:07:47
I sure would like to find an aux. transmission in good condition for my WC. Please let me know if you are interested in selling yours. Where are you located? I am located south of Bloomington, Indiana. Thanks for your time.
justin
06-21-2004 20:05:05
 Re: Re: WC aux tranny in reply to Gordon in IN, 06-21-2004 19:07:47
IM in southwestern pa. you wouldnt happen to know how to tell if its a underdrive or over drive do you? which one are you looking for? we'll probably get rid of it the tractor its self is junk. the only thing i see wrong with it is the top part of the handle is broke off but should be easy to make its just tubing.
Gordon in IN
06-22-2004 20:09:05
 Re: Re: Re: WC aux tranny in reply to justin, 06-21-2004 20:05:05
I would like to get a aux. Transmission to make the tractor go slower. I think that is referred to as an underdrive or reducing drive. The only way I know to determine the gearing is to jack up one wheel, put the regular transmission in 4'th gear and turn the engine over with the crank (or turn the main transmission input shaft if the engine is not in the tractor) 10 turns and count the turns and/or part turns of the rear wheel. Then engage the aux. transmission and turn the engine 10 more turns and count the turns and/or part turns of the wheel. The ration of the two different numbers of turns of the rear wheel will give you the aux. transmission gear ratio. Good luck
