Popping noise out the exhaust pipe
Eric in VA
06-17-2004 16:46:15
While running the AC "C" today, I noticed a Popping sound coming from the exhaust pipe. I could put my hand over the pipe and feel it and it felt like big puffs of air.
Is there something else wrong with my tractor? I havent noticed this on other ACs. It just sounds like it isnt suppose to be doing this.
Please help
ERIC
Phil Auten (TX)
06-18-2004 05:31:41
 Re: Popping noise out the exhaust pipe in reply to Eric in VA, 06-17-2004 16:46:15
Pull the rocker cover and check the valves. If the engine is missing, check the pushrods too. I had a couple jump out of the sockets on my RC, which uses the same engine as your C. Valves should be about 0.012 hot. Double check that number on the plate on the manifold, but I think that's right.
Phil
Steve in N.J.
06-17-2004 20:25:07
Eric,
Could be a couple tight valves, or just a misfiring spark plug. Check the point gap also..
Steve/B&B Custom Circuits
Sid
06-17-2004 18:58:07
My quess would be the valves.
