Allis B Rear Weights
Wayne in PA
06-16-2004 18:06:14
I purchased an Allis B with a set of rear weights that were mounted on the inside of the heavy wheel. Can someone tell me what other tractors these will fit? The casting numbers are AM 3138-5. They are flat on one side and cone shaped on the other. Thanks.
Ed
06-16-2004 19:45:45
 Re: Allis B Rear Weights in reply to Wayne in PA, 06-16-2004 18:06:14
the casting number you quoted fits the Allis C , and the allis B (with the 40"-68" tread)as in CHALMERSBOB reply...they are mounted to the inside of the wheel..... there was another style too that could go on the inside or outside,it kind of resembles a farmall weight
CHALMERSBOB
06-16-2004 19:07:57
DOES YOUR TRACTOR HAVE THE ADJUSTABLE FRONT AXLE?IF IT DOES, THEN THE REAR WHEELS ARE THE SAME AS ON THE MODEL C. THE WHEEL WEIGHTS ON A C ARE MOUNTED ON THE INSIDE TOO. BOB
Eric in VA
06-16-2004 18:35:27
Wayne,
I believe that they will only fit on a "B" if it has the flat rear hubs and wheels. i dont think they will fit on a "C" or "CA" because the hubs and wheels stick out farther and out past the outer most part of the tire and rim.
Also I think the weights are suppose to be on the OUTSIDE part of the wheel, not on the inside!
