WD STARTER REPLACEMENT
WAYNE
05-15-1999 20:33:07
I AM HAVING STARTING PROBLEMS WITH MY WD. THE CABLES AND CONNECTIONS APPEAR TIGHT AND CLEAN. AT TIMES THE STARTER JUST CLICKS AND WHEN I TRY TO START IT AGAIN IT TURNS OVER. I DON'T SEE ANY BOLTS ON THE OUTSIDE OF THE STARTER HOLDING IT TO THE BLOCK. ANY HELP WOULD BE APPRECIATED.
Tim(ny)
05-17-1999 07:24:11
 Re: WD STARTER REPLACEMENT in reply to WAYNE, 05-15-1999 20:33:07
Wayne, take the starter button cover off the starter; I think its held on with 2 screws. There are two big hunks of copper that must make a connection. Clean these up and make sure they make good contact, and I think it will help.
mm
05-15-1999 21:27:14
There is a big set screw that screws into the side of the starter nose. The only ground these starters have is where the nose touches the bellhousing and this set screw. Clean the hole the starter plugs into and tighten the set screw. Then retry the starter. Check the battery's charge.
