Clutch-adjustment
New_AC_Guy
06-15-2004 07:12:35
Hey Guys:I have a 1957 D-17 my ?? is can the clutch be adjusted.It does not slip when worked or pulling--But has alot of pedal travel when you disengage and as you engage it, if in gear it jump alittle or grabs.I don't know a whole lot about tractors yet as I am new to them,,But I would think there got to be adjustment to it..... Thanks alot for any help----BUD S.
JMS/MN
06-15-2004 11:24:40
 Re: Clutch-adjustment in reply to New_AC_Guy, 06-15-2004 07:12:35
The clutch free play is adjustable. If you are new to tractors, the first thing is to get the operator manual. Helps you with basic ID of controls, adjustments, lube requirements, etc. Beyond that, get the service manual when you want to go beyond basic maintenance.
Dave K
06-15-2004 08:59:10
If any oil or grease is getting on the clutch plates they will grab like that. As to adjustments I am not familiar with the D-17. I am a WD man! I would suggest however you ask your question on here xxxallisxxchalmersxx.com xx. Remove all x's first. Go to the discussion forumn there. I would highly recomend you get the operators and service manuals for your tractor.
Dave
Dave
