7000 PTO Bearing
Craig (MN)
06-15-2004 06:58:42
I just took out the bearing on the 1000RPM PTO shaft. Anyone know what kind of job it is to replace? There is a cover with 4 bolts but it doesn't seem to want come off with just gentle persuasion.
Clodbuster
07-11-2005 20:09:50
 Re: 7000 PTO Bearing in reply to Craig (MN), 06-15-2004 06:58:42
Took mine apart today.
Must remove the three point lift housing.
Must then remove snap ring on front of pto shaft.
You can then press or carefully drive the shaft back and remove it from housing.
Good luck.
I need the part numbers for the seals and roller bearing. Mine completely shot and unreadable.
