What is a D-19 worth?
Eric Allen
06-13-2004 11:47:40
I wonder what a good price would be for selling a D-19? It is a gas powered 6 cyl. and it runs great, great gobs of power for any job. The only problems are; the governer does,'t work well, you just have to cut it when you press the clutch so it doesn't rev to the moon, and high range doesn't work, the tractor lurches and almost locks up, but if you just leave it in low and watch the throttle, it will do ANYTHING and you'ld never know anything was wrong. It runs well, starts well, has good rubber on back ok on front, and the sheet metal is imaculate. Any guesses on price, or even what may be wrong in the high range would be appreciated. Thanks again for all your help everyone.
Jerry
06-13-2004 21:01:14
 Re: What is a D-19 worth? in reply to Eric Allen, 06-13-2004 11:47:40
Check to see if you have linkage binding going from gov. to carb. Maybe missing spring on return. High range clutch linkage overcenter levers, pins and plate probably worn out to prevent locking up. Where are you located at?
Eric Allen
06-14-2004 22:29:27
 Re: Re: What is a D-19 worth? in reply to Jerry, 06-13-2004 21:01:14
Central NY, yea we are missing a spring, have a bungie cord on there but it doesn't work too well. Any idea what to charge?
