Steel wheel B - front spindles the same as rubber?
D13
06-13-2004 04:14:36
I picked up a 42 B that originally was mounted on steel. It still has the wide rear fenders on the rear. On the front, the steel tires were cut off and the spokes welded to a rubber tire rim. The question I have is, are the spindles the same between this and my stock rubber tired version? I'd like to swap out the front axle onto my "show" tractor, which has worn out spindles welded to the arms, but need to make sure I can use the rubber tire hubs on these spindles.
Thanks!
