WD 45 PTO
Joe Currie
06-11-2004 13:27:21
I appreciate your help. My 1956 WD45 PTO won't disengage. This occured immediately following starting up/ engaging a heavy old bush hog for the first time in 2 years i.e. a lot of extra torque or what have you. Any advice is well received. Thank you, I'm farming.
Ron
06-11-2004 21:26:39
 Re: WD 45 PTO in reply to Joe Currie, 06-11-2004 13:27:21
If there is no bind on the rod down to the PTO box, and you have any idea you may have abused it... I would drain the transmision, and drop the PTO box off and SEE why it won;t shift out of gear... It is reletively easy to remove, and the lower box can get stress-cracks that will let the top "Ears" fail... they are the cast bosses that hold the idler gear..all in that little gearbox that drops off..!! maybe some debris has dropped down beside the lower driven gear, and won't let it slide over to dis-engage.... Anyway..if you drop the PTO box, check it real good for any signs of stress near the upper cast bosses.. These can take a whale of a lot of abuse, but I always follow one set of rules...I NEVER engage it, without first engaging the transmission..to stop the gears from turning...I don't want to weaken any gear teeth from grinding those gears...!! Hope it is just dirt... Good luck.. Ron.
