AC 200 Engine Question
David B
06-10-2004 15:00:44
I have an AC 200, with a bad motor. I have a couple of good leads, but the distance involved makes the price out of my range. Does anyone know if the 301 non-turbo like used in the 180 or 190 will work? I am NOT going to actually use it for work, so I don't really need the extra oomph of the turbocharger.
The tractor is located in South Central Kentucky, and there were not a lot of AC's sold there.
D Brown Utah
06-10-2004 21:48:00
 Re: AC 200 Engine Question in reply to David B, 06-10-2004 15:00:44
the engines are basicaly the same if i rember right they will bolt up the 180s usued a 2800 engine and the 200 used tho 2900 engine the engines are the same except the turbos and fuel settings
Joe(TX)
06-11-2004 17:57:14
 Re: Re: AC 200 Engine Question in reply to D Brown Utah, 06-10-2004 21:48:00
Other differances would be the oil cooler as well as the front timing cover on the 2900. Also later 200's had the oil pump driven by the crank rather than the cam. The engine will bolt in however.
