D17 Hydraulics
Mark Stewart
06-10-2004 13:28:20
The hydraulics on my 1963 D17 are stuck. I could not tell you how long it has been this way. Can the hydraulic motor or pump be removed or serviced via the access cover below and to the right of the seat, or does the tractor need to be broken in half? Also, does anyone know of any gasket kits so I can change all of the gaskets and o-rings?
Kevin (FL)
06-10-2004 20:43:16
 Re: D17 Hydraulics in reply to Mark Stewart, 06-10-2004 13:28:20
Mark,
I'm assuming you don't have a pump on the side like a Series IV, so you have the same belly pump that our '59 has. It is accessible from below. You have to remove the traction booster linkage and a plate I believe and then the cover under the pump. Probably will also need to remove the side cowling to access the linkage and lines too.
We're about to overhaul the pump on ours too so I've been looking into it. Before you pull the pump though, have you checked the line pressures with a gauge?
Mark Stewart
06-14-2004 05:00:09
 Re: Re: D17 Hydraulics in reply to Kevin (FL), 06-10-2004 20:43:16
I have'nt checked them with a gauge yet. I'll be pulling it into a shop and starting my overhaul in about two weeks. In the event that the pump is shot, is there any place that specializes in old AC parts? I'd especially like to get the hoods that go on the tractor. Mine are gone.
