Snap Coupler Coil Shank Field Cultivator
Robert Allen
06-09-2004 09:55:37
Can somebody out there enlighten me as to the purpose of a "field cultivator"? I'm familiar with row crop cultivators, but this is different. It is an AC snap coupler Coil Shank Field Cultivator. Were these any good? Anybody relate experience and/or advice?
The reason I ask is that I bought a WD45 a year ago for restoration/play farming. A neighbor down the road has one of the above, in original condition, that is to say, original paint, no cuts or welds or parts missing, rubber in need of replacement, that he'd be willing to part with for $350. It's sitting in a fence row and not being used. I thought his price was a little steep.
Any comments, advice, suggestions would be appreciated. Thanks!
Barry Coble NC
06-09-2004 20:25:00
 Re: Snap Coupler Coil Shank Field Cultivator in reply to Robert Allen, 06-09-2004 09:55:37
Robert;
The 'field cultivator' is called a 'tiller' around here. We use them to break up plowed land that has wintered over but doesn't need plowing again, in preparation for harrowing and making a seedbed. If authenticity is what you want, forget the tiller you're looking at. The original WD/WD45 tillers had no rubber in them, just round-wound steel spring shanks--sounds like you've found a lot later model piece of equipment. The old WD tillers had 7 shanks, the WD45 tillers had 9. But if the shanks have rubber in them, it's not from that era. $150 is a gracious plenty for a WD/WD45 tiller, and since the one you're looking at has rubber in the shanks, beware--it the rubber is rotted or cracked, it'll cost you a fortune to replace the inserts. Hope this helps.
Robert Allen
06-10-2004 08:28:17
 Re: Re: Snap Coupler Coil Shank Field Cultivator in reply to Barry Coble NC, 06-09-2004 20:25:00
First off, thanks much for the reply.
I must have miscommunicated as the Field Cultivator I'm looking at doesn't have rubber in the shanks. It's shanks coil around in a tight circle a couple times near where they mount to the tool bar. The rubber I mentioned are two tires, I'd guess on a 15 inch rim, that are guage wheels to regulate how deep the shanks dig. They too are original, and definitely in need of replacement. This is an 11 shank unit, and I believe it is correct to the WD45 era as the owner is retired and originally farmed with AC equipment back when it was new.
I was just looking for feedback as to it's original intended use, how well they worked, etc. Again, I appreciate your reply as it does include useful info.
Thanks again.
Barry Coble NC
06-13-2004 20:08:21
 Re: Re: Re: Snap Coupler Coil Shank Field Cultivat in reply to Robert Allen, 06-10-2004 08:28:17
Glad to help Robert. You may need to drop 2 of the shanks off for a WD45 if you have clay soil-the 11-shank was for a D17, and 9 is all a WD45 wants. Depending on where the shanks are spaced on the toolbar, you'll probably have to spin the rear wheels all the way out to clear the coils when you mount it. If the Traction Booster on your WD45 works, forget the gauge wheels unless you want to keep the implement original.
JMS/MN
06-09-2004 11:23:33
Didn't you ask this question a few days ago- the one I responded to regarding the advantages of a field cultivator? The only additonal info now is that I think his price is at least double what it should be. If you just want a FC, you could find anything much cheaper. We used to pull an 8 1/2 foot Moline with our WD45. The coil shank FC might be ok for tractor shows, but can you get replacement coils for it now? If you want to get something to dig with- get anything 8-10 feet wide that you can get parts for.
R.A.
06-10-2004 08:34:09
 Re: Re: Snap Coupler Coil Shank Field Cultivator in reply to JMS/MN, 06-09-2004 11:23:33
Hey JMS, yes, this is the same post I put on the Implement Alley board a couple days ago. Yours was the only quality reply I recieved, so I thought I'd post it here to try to get some more feedback before deciding whether to pursue the piece of equipment.
Thanks again.
