AC-B Oil Pressure
Birt Etienne
06-07-2004 16:32:10
I have a 1940 Model B and have it mostly restored. During the winter I had problems with the oil pressure gauge freezing up. After it warmed up it worked OK. So, this spring I changed the oil, oil filter anf oil pressure gauge. Now it doesn't register oil pressure. So I tried another gauge, still no pressure. When I unscrew the gauge, oil punps out the opening when the engine is running. Is there anything I should try before changing the oil pump.
Rod (NH)
06-07-2004 16:54:12
 Re: AC-B Oil Pressure in reply to Birt Etienne, 06-07-2004 16:32:10
Hi Birt,
Make sure you are NOT using the newer style NAPA 1101 oil filter. The latest design will show a lower than normal oil pressure. See my evaluation of them. Also make sure that the riser tube is in place that delivers oil up the middle of the filter.
third party image Rod
